Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
Back of pupil camera is glued on. Remove with flat-head.
Front housing comes off once the screws are removed from the frame.
Twist out the silver microphone.
Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
IR LEDs replaced by SMD LED
Soldering required here (at bottom of LED to remove).
SMD LED info: Thick black line is near the positive side of the LED
Dark side (dot) is positive side on LED.
