Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
First: Eye Camera
Remove initial frame (crack off)
Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
Back of pupil camera is glued on. Remove with flat-head.
Front housing comes off once the screws are removed from the frame.
Twist out the silver microphone.
Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
IR LEDs replaced by SMD LED
Soldering required here (at bottom of LED to remove).
SMD LED info: Thick black line is near the positive side of the LED
Dark side (dot) is positive side on LED.
2 участников успешно повторили данное руководство.
