Введение
This guide explains how to disassemble the Breville BKC600XL coffee brewer head.
  1. Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver. Reminder for reassembly; This bottom piece is first to be screwed back on. Reminder for reassembly; This bottom piece is first to be screwed back on.
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  3. Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  4. Remove the grey plastic casing. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Заключение
Antonio
Участник с: 26.09.2012
73 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 1-3, Propen Fall 2012 Member of Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 членов
Автор 6 руководств
Один комментарий
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 9
За 30 дней: 24
За всё время: 2,980
