Disassembling Canon EOS Rebel XS Top Panel
Выберете то, что вам нужно
  1. Disassembling Canon EOS Rebel XS Top Panel, Latch Side Cover: шаг 1, изображение 1 из 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Top Panel: шаг 2, изображение 1 из 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Top Panel, Disassembling Canon EOS Rebel XS Front Cover: шаг 3, изображение 1 из 1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Top Panel: шаг 4, изображение 1 из 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Disassembling Canon EOS Rebel XS Top Panel, Back Cover: шаг 5, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  6. Disassembling Canon EOS Rebel XS Top Panel: шаг 6, изображение 1 из 1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  7. Disassembling Canon EOS Rebel XS Top Panel, Top Panel: шаг 7, изображение 1 из 1
    • Remove the following ribbons with the tweezers by gently pulling on them.
    • Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
  8. Disassembling Canon EOS Rebel XS Top Panel: шаг 8, изображение 1 из 1
    • Remove the cable heads attached on the front side of the camera next to the lens mount.
    • Be gentle when puling wires lose, use the tweezers to remove the wires.
  9. Disassembling Canon EOS Rebel XS Top Panel: шаг 9, изображение 1 из 1
    • You can use your fingers to pull the top panel of the camera.
Заключение
Еще один человек закончил это руководство.
Daniel Bussone
Участник с: 01/28/11
1 260 Репутация
Автор 11 руководств
Команду
Cal Poly, Team 3-41, Regan Winter 2011 Участник Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 членов
Автор 21 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 11
За последние 30 дней: 24
За всё время: 4,089
