Введение
This guide will show you how to disassemble the back and side panel of the printer.
Выберете то, что вам нужно
Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
Remove the blue lever from its slot by pushing it back and twisting clockwise.
Close the scanner compartment and cover.
Flip the printer over so that the bottom of the printer is facing you.
Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
Use the plastic opening tool to loosen the side panel from the bottom of the printer.
6 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Good job!!!!
Where is the rest of disassembly?
