Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
While the switch is pushed forward, pull the cover away from the camera.
To remove batteries, simply allow them to fall out of the camera.
Use a fingernail to lift the clock battery out of the camera.
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
Open the battery cover.
Using the iFixit opening tool, push up gently around all edges of the camera.
Press and hold down the button shown in the blue circle.
While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
5 участников успешно повторили данное руководство.
3 Комментариев
A handy guide. I had an A590IS with a broken battery door latch on the camera body, and I managed to obtain a dead A590IS with a fully intact latch for free. So using this guide I swapped the body shells over! All fixed and working again!
