Введение
Use this guide to remove the AV port and logic board.
Выберете то, что вам нужно
Remove 2 screws from each side of the camera (4 total, 0.102 in).
Remove 2 screws from the bottom on the camera (0.138 in).
Gently pull off the front cover.
Gently pull off the back cover.
I had to remove the screw on the bottom mounting plate to get the front case cover off. The screw closest to the middle. The front plate does have a hole here that the screw goes through
remove both screws - the second holds the back plate
The cases should now be removed.
This can be a bit tricky when reassembling. All of the little tabs around the edge need to snap into their proper places, and there are three cover pieces to manage. Plus, you need to make sure that the camera/video/playback switch is properly engaged with its slider on the circuit board, otherwise you'll need to raise the back panel and reposition everything again.
oh yes , i agree lol
elbala80 -
Remove the top-left screw above the LCD screen (0.100 in).
Remove the C-shaped plate from the side of the LCD screen.
Remove the screw from the top-right of the LCD screen (0.098 in).
Remove the L-shaped bar from the right of the LCD screen.
I used this guide for a blue "made in china" version of this camera, as well as a silver "made in japan" version. The L-shaped brackets on either side of the LCD were much easier to remove for the blue one, but I was able to get them out for the silver one also with some additional coaxing. There were more pronounced tabs/notches securing the brackets to the adjacent frame on the silver one.
Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
There is a hole in the reinforced "plug" end of the LCD cable shown in Step 8. You can use a dental-type pick to remove and replace the plug easily.
Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
Use the tweezers to lift this ribbon.
Use the tweezers to gently peel this ribbon from the one underneath it.
Use the spudger to remove the lens ribbon from the circuit board.
Use the spudger to lift the ribbon.
Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
Use spudger to carefully lift the LED light off the upper-left corner of the lens.
This step omits the removal of the shutter release assembly shown in position in Step 17. Picture in Step 18 shows release assembly removed. Release assembly can be removed and set aside taking care to not disturb connection wires to expose LED light so it can be pried off the lens assembly as shown in second photo of this step.
Remove screw from top-right of logic board (0.102 in).
Remove screw on the silver plate (0.102 in).
Using the spudger, disconnect the ribbon cable located on the top of the logic board.
Remove the remaining screw (0.102 in) located on the camera strap piece.
The camera strap piece and the av port/battery/memory card assembly can now be removed.
3 участников успешно повторили данное руководство.
