Введение
This guide shows you how to open the Casio Exilim EX-Z850's outer casing and access the camera's internal components. This may be necessary to replace parts of your camera.
Выберете то, что вам нужно
Remove all four screws on the camera's side using a Phillips #00 screwdriver.
Remove all four screws on the opposite side of the camera using the same screwdriver.
Remove all four screws on the bottom of the camera using the same screwdriver.
Pry open the bottom casing.
Remove the ribbon from the LCD screen using the tweezers and set aside the bottom casing.
Pry apart the top casing using tweezers.
Remove the top casing from the camera and set aside the top casing.
To reassemble your device, follow these instructions in reverse order, starting with reattaching the top casing.
2 участников успешно повторили данное руководство.
