Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Push both tabs inward simultaneously and slide the battery out.
Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Push out the side tabs simultaneously and pull out the old RAM module.
Remove the rubber pads located on the corners of your Compaq Mini.
Unscrew all the corner screws. There are four total, one under each rubber pad.
Unscrew the screw for the bottom case located in the RAM compartment.
Remove the three screws in the silver tabs at the back of the keyboard.
Lift the keyboard away from the laptop.
Remove the eight screws that are from the plastic top cover.
Pry up the top plastic cover using a spudger.
These two tabs under the screen need to be pushed in with a spudger.
Remove the four screws that keep the bottom of the hinges attached to the base.
Pry off the top plastic cover of the display assembly.
The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
5 участников успешно повторили данное руководство.
