Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Sticky keys? Simply just want to get rid of your keyboard? Here's how.
Запчасти
Детали не указаны.
  1. Find the battery and the battery tabs located on the bottom of the Compaq Mini. Find the battery and the battery tabs located on the bottom of the Compaq Mini.
    • Find the battery and the battery tabs located on the bottom of the Compaq Mini.
  2. Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out.
    • Push the tabs inward and slide the battery out.
  3. Unscrew the two screws on the bottom of the laptop covering the memory compartment. The screws are attached to the panel.
    • Unscrew the two screws on the bottom of the laptop covering the memory compartment.
    • The screws are attached to the panel.
  4. Push out side tabs.
    • Push out side tabs.
  5. Remove the rubber pads located on the corners of your Compaq Mini. There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Unscrew all the corner screws. There are four total, one under each rubber pad. Unscrew all the corner screws. There are four total, one under each rubber pad.
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Unscrew the screw for the bottom case located in the RAM compartment. Unscrew the screw for the bottom case located in the RAM compartment.
    • Unscrew the screw for the bottom case located in the RAM compartment.
  8. Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen. Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
    • Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
Заключение
4 участников успешно повторили данное руководство.
alea
Участник с: 06.10.2010
1 366 Репутация
Автор 14 руководств
Команда
Cal Poly, Team 22-2, Maness Fall 2010 Участник Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 членов
Автор 20 руководств
Комментариев: 3
hi, steps 5 and 6 are not needed. not sure about removing RAM either. If I look on my removed keyboard, all I see are three places for screws - those located nearby battery socket.
Petr Gebelt - Ответить
I think steps 3,4,5,6,7 are not needed! The essential problem in removing the keyboard is not shown: how to lift the keyboard! Use the flat side or back of a screwdriver to push the metal strips shown in step 8 up (in the direction of the keyboard) to lift the keyboard. Put your fingers under the edge of the keyboard and pull gently but firmly. There is some resistance of the holding cover.
See also: https://www.youtube.com/watch?v=nELBz1VB...
Hans Donck - Ответить
Thank you so much for the link!
Alex -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 16,342
