Запчасти
Детали не указаны.
Make sure the camera is turned off here.
Remove batteries from the battery compartment located on the bottom of the camera
Remove SD card for the card reader compartment located on the flat side (left side) of the camera
Remove 3 screws on the flat side of the camera
All silver screws go into the side of the camera that is silver
All black screws go into the side of the camera that is black
Remove 4 screws from the bottom of the camera
Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
Use minimal force so that the plastic casing does not break
When separating the small silver sliding indicator for view/off/playback may fall out
The plastic viewing window located on the top of the camera may also become lose and fall out
Optional: Remove two black screws from top of camera on the flash side for more working space.
Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
Connect new flash by soldering copper ends to their respective ends to new flash element.
