Fix Your Stuff
Right to Repair
Parts & Tools
Введение
This guide will cover the necessary steps to unlatch and remove the upper shell from the printer.
Запчасти
Детали не указаны.
  1. To remove the top cover of the printer you have to first release it from several tabs.
    • To remove the top cover of the printer you have to first release it from several tabs.
    • Note: This may take more than one person to complete.
  2. These three are the easiest tabs to remove. They are located on the back side of the printer. Push the tab in with one of the plastic opening tools. Keep the tab pushed in by leveraging the tool between the tab and the hole. Pull up on the case so that the tab doesn't lock back into place.
    • These three are the easiest tabs to remove. They are located on the back side of the printer.
    • Push the tab in with one of the plastic opening tools.
    • Keep the tab pushed in by leveraging the tool between the tab and the hole. Pull up on the case so that the tab doesn't lock back into place.
    • Repeat this process with the furthermost right tab, then proceed with the middle tab.
  3. Note: It is recommended that step 3 and step 4 be completed simultaneously. The tabs are identical just on opposite sides. Viewing from the front of the printer, there is a tab in the lower left corner. Viewing the tab hole from the bottom of the printer.
    • Note: It is recommended that step 3 and step 4 be completed simultaneously. The tabs are identical just on opposite sides.
    • Viewing from the front of the printer, there is a tab in the lower left corner.
    • Viewing the tab hole from the bottom of the printer.
    • Insert the mini screwdriver into the marked hole and pry out the tab.
    • Push in towards the blue sticker of the printer while pulling up on the case at the same time. Use one of the tools to keep the tab pried open.
    • This tab is the easiest to break so be very careful.
  4. There is another tab in the right corner of the printer (viewing from the front). Viewing the tab hole from under the printer. Zoomed in on the tab hole.
    • There is another tab in the right corner of the printer (viewing from the front).
    • Viewing the tab hole from under the printer.
    • Zoomed in on the tab hole.
    • Follow the same instructions in step 3 to remove this tab.
  5. The final two tabs can be more difficult to release. Viewing from the front, they are located in the back left and right corners of the printer. The release points for the tabs are located in holes on the depressed area of the base (darker piece). Use the mini screwdriver to pry out the tab.
    • The final two tabs can be more difficult to release. Viewing from the front, they are located in the back left and right corners of the printer.
    • The release points for the tabs are located in holes on the depressed area of the base (darker piece).
    • Use the mini screwdriver to pry out the tab.
    • Use one of the plastic tools to keep the tab pried out. Once it releases push in towards the printer (viewing from the side) and pull up on the case.
  6. All of the tabs have now been released.
    • All of the tabs have now been released.
    • When trying to completely remove the cover, it gets caught on these two back components. Maneuvering around these can be tricky.
    • Push the cover to the right slightly and then push it backwards (out of the screen in this picture). This should give it some wiggle room. Repeat this as necessary.
  7. Now, pull the cover up and off. Now, pull the cover up and off.
    • Now, pull the cover up and off.
Заключение
Еще один человек закончил это руководство.
dante gagliardi
Участник с: 13.04.2011
45 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 20-68, Walters Spring 2011 Участник Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 3,064
