Выберете то, что вам нужно
To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
With your index finger, push in the button on the bottom of the battery to release it.
Pull the battery away from the phone.
After removing the battery, the front phone casing becomes accessible.
Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
Remove these two screws using the Torx T6 Screwdriver.
Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
Remove these two screws with a SP 2.6 screw driver.
Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
Locate the circuit board on the rear side of the front phone casing (right side of image).
Locate the mounting screws (indicated by red circles), which attach the board to the rear side of the front phone casing.
Using the SP2.6 u-shaped screw driver in one hand, loosen and remove both center screws. Hold the back part of the screw with the metal tweezers.
Locate the final screw at the top of the phone near the antenna, as shown by the red circle.
Using the U-shaped screw driver, remove the top screw.
With one hand on the circuit board and one hand on the phone casing, carefully pull apart the circuit board from the front panel casing.
