Выберете то, что вам нужно
Remove the hard plastic ring that is covering the 2 phillips screws at the bottom of the unit.
Removing the 2 screws will release the filter. Note that there should be 2 brass poles that connects the two pieces together. One broke in the picture shown as I pried it before.
The condenser is not attached to the casing and is easily removeable. It is connected to the main PCB so do be careful.
Inside you will see another smaller PCB that housed the 3.5mm audio jack. This needs to be removed first before the main PCB as the USB connector is slightly too large to slide through.
