Disassembling Flip Video Circuit Board
Выберете то, что вам нужно
  1. Disassembling Flip Video Circuit Board, Outer Shell: шаг 1, изображение 1 из 2 Disassembling Flip Video Circuit Board, Outer Shell: шаг 1, изображение 2 из 2
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Disassembling Flip Video Circuit Board: шаг 2, изображение 1 из 1
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Disassembling Flip Video Circuit Board: шаг 3, изображение 1 из 2 Disassembling Flip Video Circuit Board: шаг 3, изображение 2 из 2
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Disassembling Flip Video Circuit Board: шаг 4, изображение 1 из 1
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Disassembling Flip Video Circuit Board: шаг 5, изображение 1 из 1
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Disassembling Flip Video Circuit Board, Circuit Board: шаг 6, изображение 1 из 1
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  7. Disassembling Flip Video Circuit Board: шаг 7, изображение 1 из 1
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
  8. Disassembling Flip Video Circuit Board: шаг 8, изображение 1 из 1
    • Disconnect the USB port cable from the back side of the circuit board.
  9. Disassembling Flip Video Circuit Board: шаг 9, изображение 1 из 1
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
Заключение
Еще один человек закончил это руководство.
Elizabeth
Участник с: 04/15/10
100 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 26-21, Regan Spring 2010 Участник Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 членов
Автор 12 руководств
Один комментарий
Thank you. Where is the reset button on these first generation Flip Videos (mine doesn’t have one visible on outside, must be on inside.
sherrygray - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 2,220
