Выберете то, что вам нужно
Flip the device to the backside, and locate the metal tab at the center of the back cover.
Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
Gently pull the wire ribbon from the white connector.
5 участников успешно повторили данное руководство.
6 Комментариев
Hello, friend. Name’s Arthur. I have this old Garmin Etrex H GPS device (the yellow one) and it looks very similar to your Etrex Vista H, but it has no stick button. The disassembling method suited just fine here, so I thank you Sir for this tutorial. I was trying to disassembly my Garmin because I am having a problem with its display. There’s a vertical line that its not displaying, so I decided to take a look. However, there was something strange. The display contacts were not locked by a connector, but by something like a durex tape. Seemed very precarious. Have you ever disassembled this yellow Etrex H model? Any ideas on how to solve my problem?
I forgot to remove battery for years and the battery chamber got damaged. So chamber was cleaned and repaired but now I cannot on it.
