Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
A side panel is located on each side of the device. The right side panel, containing the button(s), controls the track being selected as well as the volume of the device. There are no prerequisites required for this guide.
- A pry bar is necessary to remove the panel.
Выберете то, что вам нужно
Use the plastic opening tool.
Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
The side panel can now be detached using your fingers.
The buttons can be dislodged by turning the panel over and shaking it, if necessary.
After disassembling, the device and its components should look similar to that depicted in the cover image (top right of page).
