Введение
There are no prerequisites required for this disassembly, but a spudger or similar opening tool is required to remove the panel.
Запчасти
Никакие детали не требуются.
  1. Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
    • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
    • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Remove the button from the side panel.
Заключение
After disassembly, the device components should look similar to that which is depicted in the cover image (top right of page).
Alexander
Участник с: 09.03.2012
101 Репутация
Автор 9 руководств
Команда
Clemson, Team 15-3, Benson Spring 2012 Member of Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 членов
Автор 9 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,013
