Disassembling HP Compaq NC6120 Laptop
Выберете то, что вам нужно
  1. Disassembling HP Compaq NC6120 Laptop, Disassembling HP Compaq NC6120 Laptop: шаг 1, изображение 1 из 3 Disassembling HP Compaq NC6120 Laptop, Disassembling HP Compaq NC6120 Laptop: шаг 1, изображение 2 из 3 Disassembling HP Compaq NC6120 Laptop, Disassembling HP Compaq NC6120 Laptop: шаг 1, изображение 3 из 3
    • Flip laptop so the backside is facing upwards.
    • Pull the two plastic switches at the top of the backside of the computer outwards, and remove the battery.
  2. Disassembling HP Compaq NC6120 Laptop: шаг 2, изображение 1 из 2 Disassembling HP Compaq NC6120 Laptop: шаг 2, изображение 2 из 2
    • Remove all 13 screws from the back panel of the computer (includes the two torx screws under the battery and the two under the ram memory panel).
    • Remove the four screws at the hinge of the computer (also attaching the back panel to the rest of the computer).
    • All screws are 9.8mm 3.0 flatheads except for the two under the battery which are T9 torx.
    Remove the leftmost screw marked with blue circle. Push the drive out. You're done. Rest of this "guide" is just making you do incredible amount of work for no reason whatsoever. The DVD drive is attached LITERALLY with one screw, and that is the screw under the leftmost blue circle.
    Antti Vahtera - Ответить
  3. Disassembling HP Compaq NC6120 Laptop: шаг 3, изображение 1 из 2 Disassembling HP Compaq NC6120 Laptop: шаг 3, изображение 2 из 2
    • Open up the laptop so that the screen is facing towards you. Push the monitor back until it is flat, parallel to the keyboard.
  4. Disassembling HP Compaq NC6120 Laptop: шаг 4, изображение 1 из 2 Disassembling HP Compaq NC6120 Laptop: шаг 4, изображение 2 из 2
    • Using the iFixit opening tool, remove the plastic panel located between the keyboard and monitor. It should pop off easily with the spudger and can then be pulled away.
  5. Disassembling HP Compaq NC6120 Laptop: шаг 5, изображение 1 из 2 Disassembling HP Compaq NC6120 Laptop: шаг 5, изображение 2 из 2
    • Remove the white cable attached to the just-removed plastic panel from the motherboard.
  6. Disassembling HP Compaq NC6120 Laptop: шаг 6, изображение 1 из 2 Disassembling HP Compaq NC6120 Laptop: шаг 6, изображение 2 из 2
    • Flip the keyboard away from the monitor, rotating it so that the keys are face down on the mousepad. Remove the black cord at the bottom of the keyboard that connects it to the motherboard. The keyboard is now free and can be removed.
    I can’t remove the keyboard
    Saudin Jasar - Ответить
  7. Disassembling HP Compaq NC6120 Laptop: шаг 7, изображение 1 из 3 Disassembling HP Compaq NC6120 Laptop: шаг 7, изображение 2 из 3 Disassembling HP Compaq NC6120 Laptop: шаг 7, изображение 3 из 3
    • Remove the two 9.8mm 3.0 flathead screws. There is one at each of the hinges.
  8. Disassembling HP Compaq NC6120 Laptop: шаг 8, изображение 1 из 3 Disassembling HP Compaq NC6120 Laptop: шаг 8, изображение 2 из 3 Disassembling HP Compaq NC6120 Laptop: шаг 8, изображение 3 из 3
    • Unplug the black cable with rectangular white plastic head from the motherboard. It is located at the top left of the motherboard, directly below the left hinge.
  9. Disassembling HP Compaq NC6120 Laptop: шаг 9, изображение 1 из 2 Disassembling HP Compaq NC6120 Laptop: шаг 9, изображение 2 из 2
    • Pull the monitor directly upwards from where it lay. The two metal hinges should easily slide out of their holes and the monitor will be disconnected from the motherboard.
  10. Disassembling HP Compaq NC6120 Laptop: шаг 10, изображение 1 из 3 Disassembling HP Compaq NC6120 Laptop: шаг 10, изображение 2 из 3 Disassembling HP Compaq NC6120 Laptop: шаг 10, изображение 3 из 3
    • Using the iFixit opening tool, pry the black plastic panel (with mousepad) off of the motherboard.
  11. Disassembling HP Compaq NC6120 Laptop: шаг 11, изображение 1 из 3 Disassembling HP Compaq NC6120 Laptop: шаг 11, изображение 2 из 3 Disassembling HP Compaq NC6120 Laptop: шаг 11, изображение 3 из 3
    • Unplug the white cord connecting the mousepad to the motherboard from the motherboard, and pull off the entire plastic panel.
    Hi Good Sir please help me for i dont know what kind of Hard Drive connector for this Laptop,because i cant install a Hard drive for this Computer?Please this is my email address: onyotgonz1973@gmail.com,Hopefully this can be Solved,thank you in Advance and More Power to all of you.
    Antonio Gonzalez - Ответить
Заключение
8 человек успешно провели ремонт по этому руководству.
Mateo Cuellar
Участник с: 04/08/15
601 Репутация
Автор 4 руководств
Команду
Cal Poly, Team 17-4, Forte Spring 2015 Участник Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 членов
Автор 6 руководств
1Комментарий к руководству
bravo j'ai bien reussi
merci
Zitouni Lebrieki - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 11
За последние 30 дней: 59
За всё время: 9,662
