Введение
In order to replace the RAM, hard drive, or wireless card in the laptop you must first remove the back panel, as shown in this guide.
Запчасти
Детали не указаны.
  1. Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. The battery is held in by a latch in the front and tabs in the back.
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. Unscrew one Phillips #1 screw from the back panel.
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. Slide the back panel down and pull it up. Slide the back panel down and pull it up.
    • Slide the back panel down and pull it up.
Заключение
6 участников успешно повторили данное руководство.
John Sutton
Участник с: 24.04.2014
1 524 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 11-51, Amido Spring 2014 Участник Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 членов
Автор 12 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 2,486
