Выберете то, что вам нужно
Use a plastic opening tool to lift the white clip up, towards the screen.
Pull the white cable with blue head, away from the clip.
With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips.
Rotate the top panel away from you, keeping the back near the hinge of the laptop to avoid damaging the speaker cable.
Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard.
Set aside the top panel until your are ready to reassemble your laptop.
