Выберете то, что вам нужно
Power off your device.
Remove the bottom cover by sliding it off.
Remove the SIM card.
Remove the four screws securing the bottom casing.
Two 3.0 mm Phillips #0 screws in the top left and right corners.
Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
Use a plastic opening tool to pry open the bottom casing.
Remove the bottom casing by pulling it towards you.
Почти готово!
Заключение
