Выберете то, что вам нужно
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Remove the highlighted screw with a Phillips #1 screwdriver.
Pull the hard drive out.
Rotate the ThinkPad so that the hard drive bay is facing you.
Remove the black cover to reveal a 14.8mm screw.
Remove the uncovered screw with a Phillips #0 screwdriver.
Lift the front end of the keyboard as shown.
Using your fingers, remove the black film cover.
Locate the connector attached to the motherboard.
Disconnect the ribbon cable by removing the connector.
Lift and remove the keyboard.
Remove the two 5.6mm screws.
Remove the 16.7mm screw.
Remove the 5.6mm screw on the left side of the three-pronged connector.
Remove the other two 16.7mm screws.
Lift and remove connector.
Turn the laptop so that the back is facing you.
Remove the four 5.6mm long screws.
Remove the following screws from the fan retention bracket:
Single 5.6 mm screw.
Three 16.1 mm screws.
Lift the fan/heatsink assembly up.
Locate the fan power cable and pull upwards near the connector.
Remove the fan/heatsink assembly.
Use a flathead to turn the screw 180 degrees.
Remove the CPU by lifting it upwards.
