Введение
In this step-by-step guide, you will be removing the speakers from the Thinkpad A30 for replacement.
Инструменты
Запчасти
Детали не указаны.
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Rotate the ThinkPad so that the hard drive bay is facing you.
Remove the black cover to reveal a 14.8mm screw.
Remove the uncovered screw with a Phillips #0 screwdriver.
Lift the front end of the keyboard as shown.
Using your fingers, remove the black film cover.
Locate the connector attached to the motherboard.
Disconnect the ribbon cable by removing the connector.
Lift and remove the keyboard.
Remove the two 5.6mm screws.
Remove the 16.7mm screw.
Remove the 5.6mm screw on the left side of the three-pronged connector.
Remove the other two 16.7mm screws.
Lift and remove connector.
Turn the laptop so that the back is facing you.
Remove the four 5.6mm long screws.
Locate the 4 screws that will need to be removed.
Remove the 5.6mm (yellow) and three 16.1mm (red) screws.
Lift the fan/heatsink assembly up.
Locate the fan power cable and pull upwards near the connector.
Remove the fan/heatsink assembly.
Locate the floppy drive bay.
Remove the four 5.6mm screws.
Remove the 16mm screw.
Turn the laptop over so the battery is facing you.
Locate the modem and ethernet card bay.
Remove the two 5.3mm cover screws.
Gently lift the cover.
Remove the four 9.1mm screws attached to the modem and ethernet cards.
Gently lift the modem and ethernet cards.
Locate the hard drive slot.
Remove the 8.8mm screw with a Phillips #0 screwdriver.
Turn the laptop over again and orient it as shown.
Lift the left side of the floppy disk bay and and pull it out.
Locate the CD Drive Bay
Remove the three 5.6mm screws.
Lift the right side and pull the CD drive bay out.
Remove the 5.6mm screws on each speaker.
Pull the right speaker out, making sure there is still slack in the wire.
Lift the left speaker out.
Pull the blue tab that holds the speaker chip and pull the chip out.
Remove the speaker data and power cables by pulling them from the motherboard.
You have successfully removed the ThinkPad A30 speakers.
Еще один человек закончил это руководство.
