Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The lower bracket needs to be removed to get to some components of the laptop.
Выберете то, что вам нужно
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
The metal bracket will now be free to move, grasp it and remove it from the device.
Remove the small rubber piece that is covering the T42's microphone,
Еще один человек закончил это руководство.
