Введение
How to remove the edge cover of the IBM ThinkPad T42 access some of the components of your device.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
