Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide will present easy, step by step instructions on how to remove the front side of the IBM WorkPad c3 case. This case is glued together, so time will need to be spent heating the glue. This time varies, but you should expect to spend at least 10 minutes heating.
Запчасти
Детали не указаны.
  1. Turn the device over so that the screen is facing down. In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  2. Using a hair dryer, slowly heat the edges of the WorkPad.
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use a plastic opening tool to pry the back case from the WorkPad. If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
  5. Turn the device over, so that the screen is laying on a flat surface. Turn the device over, so that the screen is laying on a flat surface.
    • Turn the device over, so that the screen is laying on a flat surface.
  6. If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat. Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case. The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
    • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
    • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
    • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
  7. The device will be extremely hot. Use a towel or oven mitt to grab it. Using the Plastic Opening Tools, take the front of the case off.
    • The device will be extremely hot. Use a towel or oven mitt to grab it.
    • Using the Plastic Opening Tools, take the front of the case off.
    • If the case is difficult to remove, try repeating step 2.
    • The power button at the top of the device will be loose once the front part of the case is removed.
Заключение
Emily Falkenstein
Участник с: 05.10.2010
75 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 21-35, Regan Fall 2010 Участник Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 2,301
