Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
For most of the fixes to this stereo, you must open up the device. To do so, you must remove the bottom panel or shell to get to the inside parts.
Выберете то, что вам нужно
Flip the stereo so the CD opening is face down.
With two fingers, pinch the tabs and lift up to open the battery protection cover.
Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
Repeat until all eight batteries are removed.
Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
Use the same screwdriver to remove four more 6mm screws along the outside of the case.
With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
