Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover
Выберете то, что вам нужно
  1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: шаг 1, изображение 1 из 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: шаг 1, изображение 2 из 2
    • Using a spudger, gently pry off the aluminum drip ring.
  2. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 2, изображение 1 из 1
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 3, изображение 1 из 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 3, изображение 2 из 2
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 4, изображение 1 из 1
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 5, изображение 1 из 1
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 6, изображение 1 из 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 6, изображение 2 из 2
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 7, изображение 1 из 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 7, изображение 2 из 2
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: шаг 8, изображение 1 из 1
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
Заключение
32 участников успешно повторили данное руководство.
Chris Gonzales
Участник с: 10/12/14
1 519 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 14-28, Maness Fall 2014 Участник Cal Poly, Team 14-28, Maness Fall 2014
CPSU-MANESS-F14S14G28
4 членов
Автор 22 руководств
24 Комментариев
Well fine job! Just finished and t works!!!
James Anderson - Ответить
Instruccion is exelent but I veleave the problem is electric. can you give aidea. dhe machine does’nt work at all
Aristides Aleman - Ответить
Thank you! I'm repainting my white mixer a deep cherry red gloss to match my kitchen. These mixers can last 20+ years, if you take care of them. But, who wants the same color kitchen for that long? Bonus: saved $50+ by painting it the color I wanted, rather than pay the extra for a mixer from the colored choices.
Heather Schrader - Ответить
Do the motor housing sometimes become to hard to remove? I followed all the steps yet it still acts as if something inside the housing is keeping it from coming off.
Royce M - Ответить
Nothing else, only the planetary assembly, and the 9 big housing screws. Once those are off, it can take a lot of jiggling and persistence, mostly because there’s a vacuum between the vertical shaft and the bushing inside. Remember to loosen the cord in case to prevent yanking it accidentally when the cover comes off.
Ariel Cornejo -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 35
За последние 7 дней: 288
За последние 30 дней: 1,319
За всё время: 95,958
