Введение
This guide will give step by step instructions on disassembling the LG VX8300 to reach the logic board and internal parts.
Выберете то, что вам нужно
Power off the device by holding down the red button labeled PWR.
Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while applying the pushing force at the top to remove the cover completely.
Place your finger into the semicircle gap on top of the battery.
Apply force downward and out, so the battery pops out of the phone.
Use a Phillips #00 screwdriver to remove all four 3mm screws from the back of the phone.
Use your fingers to gently separate the front plate from the phone. You may need to slide a plastic opening tool along the crevice between the faces to separate it more easily.
Remove the casing after it has been detached. The logic board is now fully accessible.
2 участников успешно повторили данное руководство.
