Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Steps to remove LG VX8500 case
Запчасти
Детали не указаны.
  1. Slide the battery release up.
    • Slide the battery release up.
  2. Remove the battery by lifting away from the case.
    • Remove the battery by lifting away from the case.
  3. Remove the 2 screw covers next to the rear speaker with a Push Pin.
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  5. Remove the 4 cover screws with a Philips #00 screwdriver.
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  6. Use the iPod opening tool to pry off the back casing.
    • Use the iPod opening tool to pry off the back casing.
  7. Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  8. Separate the casing halves.
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
Заключение
Nathan Jones
Участник с: 10.04.2010
89 Репутация
Автор 10 руководств
Команда
Cal Poly, Team 34-55, Forte Spring 2010 Участник Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 членов
Автор 20 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 3,291
