Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections
Выберете то, что вам нужно
  1. Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections, Interior Soldered Wire Connections: шаг 1, изображение 1 из 1
    • The back panel (pictured left) has a black wire (end of wire circled red). The wire solders to the bottom right corner of the card drive.
    • The front panel (pictured right) has a black and red wire (end of wired circled green). This wire solders to a small circular spot next to where the black wire connects to the back (from above).
Заключение
ewkpates
Участник с: 05/03/12
133 Репутация
1 руководство автора
2 Комментариев
To open the leappad top start with, remove battery covers and the 6 screws.
The two halves slide, bottom half towards cartridge slot, to make it harder they have used double sided tape on the bottom platic tounges, so a scredriver in the bottom will be needed to prize the slide.
Lawrence - Ответить
Good stuff. I'm trying to slide the back plate upward, but to no avail. You mentioned tape. Where exactly is it located?
John - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 5,938
