Введение
You will learn how to remove the scroll wheel from mount.
Запчасти
Детали не указаны.
  1. Hold the mouse so that the bottom is facing up.
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Place the mouse so that the bottom is resting against a hard surface. Lift the top cover of the mouse gently, and remove it.
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Locate the scroll wheel on the mouse. Grab the scroll wheel with your thumb and index finger. Gently lift up, to remove the scroll wheel from the mouse.
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Locate the spring on the scroll wheel, and carefully remove the spring. Locate the spring on the scroll wheel, and carefully remove the spring.
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down. Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Use the images to locate where the resistance spring is. This spring will easily fall off. Grab the scroll wheel and its mount and gently pull them apart.
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
Заключение
13 участников успешно повторили данное руководство.
Maximilian Betkowski
Участник с: 11.01.2013
229 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 5-14, Forte Winter 2013 Участник Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 членов
Автор 7 руководств
Комментариев: 7
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - Ответить
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - Ответить
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - Ответить
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - Ответить
the resistence spring falled off on mine how do i out it back on help
Tay Carr - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 16
За всё время: 5,570
