Запчасти
No parts specified.
  1. First be sure to turn the power switch to the off position.
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Now remove the battery. On the back of the device locate the battery cover. Remove it by pushing down on the clip.
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  4. Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners. Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  5. Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
Итог
MacKinley
Участник с: 22.10.2013
675 Reputation
Автор 5 руководств
University of Maryland, Team 1-1, Shastany Fall 2013 Member of University of Maryland, Team 1-1, Shastany Fall 2013
UMD-SHASTANY-F13S1G1
3 членов
Автор 5 руководств
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 1,375
