Disassembling Marshall MS-2 Partner Circuit Board
Выберете то, что вам нужно
  1. Disassembling Marshall MS-2 Partner Circuit Board, Disassembling Marshall MS-2 Micro Amp Case Disassembly: шаг 1, изображение 1 из 1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Partner Circuit Board: шаг 2, изображение 1 из 3 Disassembling Marshall MS-2 Partner Circuit Board: шаг 2, изображение 2 из 3 Disassembling Marshall MS-2 Partner Circuit Board: шаг 2, изображение 3 из 3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Partner Circuit Board: шаг 3, изображение 1 из 2 Disassembling Marshall MS-2 Partner Circuit Board: шаг 3, изображение 2 из 2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Partner Circuit Board: шаг 4, изображение 1 из 1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: шаг 5, изображение 1 из 2 Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: шаг 5, изображение 2 из 2
    • Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
  6. Disassembling Marshall MS-2 Partner Circuit Board: шаг 6, изображение 1 из 1
    • Remove the 7/16" phillips head screw.
  7. Disassembling Marshall MS-2 Partner Circuit Board: шаг 7, изображение 1 из 1
    • Grab the headphone jack from inside the case and pull it toward the speaker until you can fully remove it from the device.
Заключение
3 человек успешно провели ремонт по этому руководству.
MacKinley
Участник с: 10/22/13
816 Репутация
Автор 5 руководств
Команда
University of Maryland, Team 1-1, Shastany Fall 2013 Участник University of Maryland, Team 1-1, Shastany Fall 2013
UMD-SHASTANY-F13S1G1
3 членов
Автор 5 руководств
1 Комментарий к руководству
There Is a toroidal transformer inside ?
Jack redmond - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 8
За всё время: 2,037
