Введение
With this guide you can take your MM-4 from one solid brick of a speaker to four parts and a bunch of screws. This is useful if you are replacing a bad driver, or if the connector becomes damaged and you need to replace it.
Выберете то, что вам нужно
Turn the speaker face down, so the connector side is up.
Remove the four #2 Philips screws on the back plate.
Remove the foam insert to expose the two spade connectors.
Carefully separate the connectors
Turn the speaker so the grill side is up.
Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
The grill is not glued on, but may require a bit of prying to remove.
Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
4 участников успешно повторили данное руководство.
2 Комментариев
So I took one of my MM-4 apart because something was rattling. Turns out it has a loose magnet assembly. It must have been dropped in shipping.
Do you by any chance still have it?
I have two of them already and with some zipties and rubber they sound great again…
Would you by any chance ship the broken driver over to me?
