Введение
The Circuit board has the screen and microphone attached, but the speaker and antenna can be modified separately.
  1. First, apply pressure with your thumb on the top of the battery cover.
    • First, apply pressure with your thumb on the top of the battery cover.
  2. Next, pull down on the cover until it begins to slide.
    • Next, pull down on the cover until it begins to slide.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  5. Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  6. Detach back part of the case by gently lifting up.
    • Detach back part of the case by gently lifting up.
  7. Remove the old or broken circuit board from the front case.
    • Remove the old or broken circuit board from the front case.
    • Clip the red and black wires at the base of the motherboard to completely separate it from the radio case.
Заключение
2 участников успешно повторили данное руководство.
James Tucker Dunn
Участник с: 18.01.2013
371 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 19-43, Regan Winter 2013 Member of Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 членов
Автор 9 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 3
За всё время: 700
