Введение
The speaker is attached to the circuit board with two wires and is glued onto the front case. After the speaker is removed the new speaker will need to be re-glued and re-soldered into place.
  1. First, apply pressure with your thumb on the top of the battery cover.
    • First, apply pressure with your thumb on the top of the battery cover.
  2. Next, pull down on the cover until it begins to slide.
    • Next, pull down on the cover until it begins to slide.
  3. Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  6. Detach back part of the case by gently lifting up.
    • Detach back part of the case by gently lifting up.
  7. Remove the circuit board from the front part of the radio case.
    • Remove the circuit board from the front part of the radio case.
    • Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
  8. Scrape off the glue on the outer lining of the speaker using the metal spudger.
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  9. Pry the speaker from the case using the metal spudger.
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  10. The speaker is now disassembled!
    • The speaker is now disassembled!
Заключение
3 участников успешно повторили данное руководство.
James Tucker Dunn
Участник с: 18.01.2013
371 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 19-43, Regan Winter 2013 Member of Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 членов
Автор 9 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 470
