Введение
The Motorola ES400 is used mostly in harsh environments and is rated to military spec but can still be vulnerable to being damaged.
Выберете то, что вам нужно
After all 6 screws have been removed, start by using a plastic pry tool to separate the back panel from the side frame.
Continue along the side near the volume buttons slowly seperating the back panel from the frame.
Once the back panel has been seperated from the frame slowly take it off, being careful not to break any plastic parts/clips.
Keep track of your screws.
Unscrew the 2 Philips head (+) screws to remove the camera flash module.
This unit has a broken micro usb charging port.
After the camera module has been removed pull up any tape covering the digitizer flex cable.
Slowly lift the logic board out of the frame starting at the bottom of the phone.
Один комментарий
This disassembly guide was provided by Wires Computing Electronics Repair. for help with any repairs in Burlington Vermont please visit: www.wirescomputing.com
