Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide details how to remove the internal backplate to expose the speaker, the headphone jack, and the logic board.
  1. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it.
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Use your fingers to push the battery upward from the bottom. Lift upwards to remove the battery. Lift upwards to remove the battery.
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Unscrew the antenna in a counter-clockwise fashion. Remove the aluminum cover.
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Unscrew the 3 screws shown. Lift up the right part of the Nextel logo and unscrew the screw underneath. Lift up the right part of the Nextel logo and unscrew the screw underneath.
    • Unscrew the 3 screws shown.
    • Lift up the right part of the Nextel logo and unscrew the screw underneath.
  5. DO NOT force the cover off as it could damage the ribbon cable! Gently lift the back cover off.
    • DO NOT force the cover off as it could damage the ribbon cable!
    • Gently lift the back cover off.
  6. Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board.
    • Carefully pry off the connection between the headphone jack and logic board.
Заключение
Grant Glazebrook
Участник с: 14.04.2010
7 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 29-61, Johann Spring 2010 Участник Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,255
