Введение
The lock on my Nikon SB-400 was not working, it was stuck in the lock position and could not be mounted or removed. Ultimately it was a broken mechanism within the flash, but it required a disassembly of the unit to learn this.
Выберете то, что вам нужно
Remove the SB-400 flash from the camera if able.
Remember in my case that the flash is unable to be removed from the camera, so remove batteries from both.
The SB-400 uses two AA batteries.
Remove the two screws from the bottom of the flash.
Remove the two screws from under the battery cover.
Use a spudger around the split near the battery cover to remove the top cover.
If you are not confortable discharging a capacitor, it is recommend to bring the unit to a professional for repair.
As you can see, a flash capacitor is very large and the risk of shock must be addressed. I discharged it using a screw driver with a plastic handle.
Lift the plastic clips on the connectors and pull the ribbon wires out.
Remove the two screws holding down the PCB.
Move the PCB out of the way to expose the battery case. The wires should remain attached.
Remove the battery case by sliding out the middle spacer and set it aside.
Leverage the battery case up and forward to remove.
Move the battery case out of the way, the wires should remain attached.
Remove the small silver screw holding the ribbon wires in place.
Remove the four screws that hold the lock plate in place.
With the four screws removed, the hot shoe (metal plate in contact with the camera) will drop off the flash.
The reassembly is the reverse of the disassembly.
Ensure these two fastener holes are clear when the top cover in installed to avoid damaging wires.
