Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Removing the Main Display
Выберете то, что вам нужно
Apply pressure on the cover while simultaneously sliding the cover downward.
Remove the back battery cover.
Insert the spudger between the base of the phone and the phone battery.
Position the phone so that the battery won't fall out of the phone.
Carefully lift the battery out of the phone.
Find the slight crease on the side that divides the display assembly in half.
Slowly wedge the spudger into the crease.
Run the spudger all along the crease while lifting up.
Separate the front cover from the front base.
Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
