Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Apply pressure on the cover while simultaneously sliding the cover downward.
Remove the back battery cover.
Insert the spudger between the base of the phone and the phone battery.
Position the phone so that the battery won't fall out of the phone.
Carefully lift the battery out of the phone.
Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
2 screws at the bottom
2 screws at the top
Insert the spudger in tabs between the outer casing and the inside frame.
Slide the spudger upwards.
The phone should now be in two different sections.
1) The rear case of the phone.
2) The motherboard and the rest of the phone.
Еще один человек закончил это руководство.
