Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide helps you remove the display from the phone.
Запчасти
Детали не указаны.
  1. Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone. Lift the battery case off of the phone.
    • Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone. The battery should lift out with minimal resistance. The battery should lift out with minimal resistance.
    • Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone.
    • The battery should lift out with minimal resistance.
  3. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Locate the notch on the bottom right corner of the phone. Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone. Continue to slide the screwdriver towards the top edge of the phone.
    • Locate the notch on the bottom right corner of the phone.
    • Beginning at this point, slide the head of the screwdriver between the front casing and the rest of the phone.
    • Continue to slide the screwdriver towards the top edge of the phone.
    • The front casing should eventually pop off.
  5. Locate the four screws on the upper half of the phone as indicated in the photo. Using the screwdriver indicated, unscrew each of these four fasteners. The LCD screen can be easily taken off once these screws are removed.
    • Locate the four screws on the upper half of the phone as indicated in the photo.
    • Using the screwdriver indicated, unscrew each of these four fasteners.
    • The LCD screen can be easily taken off once these screws are removed.
Заключение
Еще один человек закончил это руководство.
Erik Lindahl
Участник с: 18.04.2010
48 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 10-46, Garner Spring 2010 Участник Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
4 членов
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,474
