Введение
This guides you through removing the keypad.
Выберете то, что вам нужно
Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
Lift the battery case off of the phone.
Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
The battery should lift out with minimal resistance.
Insert a spudger into the indention on the bottom right side of the device.
Slide the spudger upward to a second indention at the top of the phone.
The front casing will detach from the phone.
With the front casing removed, the keypad can easily be pulled off the back of the front casing.
In all probability, it will already have fallen out and no removal is required.
Еще один человек закончил это руководство.
