  1. To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it. Now slide the back cover off of the phone.
    • To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it.
    • Now slide the back cover off of the phone.
  2. Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
    • Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Use your finger to lift the battery out.
    • Use your finger to lift the battery out.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver. Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
    • Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
  5. After the screws have been removed, there is nothing else securing the front cover to the rest of the phone. Simply remove the cover by pulling it up and off.
    • After the screws have been removed, there is nothing else securing the front cover to the rest of the phone. Simply remove the cover by pulling it up and off.
  6. After casing and keyboard have been taken off, remove the screws holding the screen in place using a T-6 for the screws in the middle of the red circles and a T-5 for the screw in the middle of the red square. Lift ribbon off of the contact with the logic board
    • After casing and keyboard have been taken off, remove the screws holding the screen in place using a T-6 for the screws in the middle of the red circles and a T-5 for the screw in the middle of the red square.
    • Lift ribbon off of the contact with the logic board
    • *When reassembling, make sure to firmly press contacts into place to ensure a connection is made between ribbon and logic board
  7. Once the screws are out, gently pull the screen off of the phone. *NOTICE* The sticker that attaches the display (in the middle of the blue square again) and the logic board is to be removed safely and be sure not to rip this apart. Finally, pull the silver case off to completely free the cracked or damaged screen.
    • Once the screws are out, gently pull the screen off of the phone. *NOTICE* The sticker that attaches the display (in the middle of the blue square again) and the logic board is to be removed safely and be sure not to rip this apart.
    • Finally, pull the silver case off to completely free the cracked or damaged screen.
  8. Remove the speaker by pulling it off of the display frame. The speaker is connected to the display frame by a ring of adhesive foam (visible in second picture). By removing the speaker, this foam is torn. However, the speaker sticks quite well to the frame without reapplication of any adhesive.
    • Remove the speaker by pulling it off of the display frame.
    • The speaker is connected to the display frame by a ring of adhesive foam (visible in second picture). By removing the speaker, this foam is torn. However, the speaker sticks quite well to the frame without reapplication of any adhesive.
Заключение
Christopher Patton
Участник с: 07.04.2011
196 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 9-63, Walters Spring 2011 Member of Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 членов
Автор 12 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,743
