Выберете то, что вам нужно
First remove back cover, battery, chip and memory card .
Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
33 участников успешно повторили данное руководство.
4 Комментариев
does anyone know if e71 have any battery on board? time and date keep resetting with battery removed.
Yes there is, under the keypad, 3/4 of the way down the left side of looking from the front. It is soldered on to the board so take good care.
Hi
I have this phone, but I can not charge it ,Because it has short in board ,plus it very short charger soket (female ), i’m use now extirnal charger only
what can i do ?
Very clear tutorial !
The pictures are well lit, and the instructions are good :)
Thanks !
