Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
Remove 3 screws from the front of the camera using a #00 screwdriver.
Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
Using a plastic spudger, lift up the black clips.
Still using the plastic spudger, detach the gold connector strip and white connector strip.
Using both hands, pull the camera apart into two pieces.
Еще один человек закончил это руководство.
