Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Remove the five Phillips #00 bottom and right side panel screws.
Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
Remove the three Phillips #00 screws from the front of the camera.
Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
Using a plastic spudger, lift up the black clips.
Still using the plastic spudger, detach the gold connector strip and white connector strip.
Using both hands, pull the camera apart into two pieces.
Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
Unscrew two screws on the right side of the camera using a #00 screwdriver.
Still using the spudger, detach the gold wire tape connectors from the logic board.
In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger.
