Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Press battery to the right.
Then lift up battery pack to remove.
Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
Lift the rubber cap at the top right to reveal the sixth screw.
Remove the six screws using the T5 Torx screwdriver.
Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
Remove the small plastic insert at the bottom of the phone.
Continue with plastic pry tool all the way around the phone to remove the back housing.
Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
Separate the logic board from the case by lifting and pulling out the bottom.
Еще один человек закончил это руководство.
2 Комментариев
note: if you need to replace the logic board, follow this guide, insert a new board, and then follow the steps in reverse order to get a working phone.
i try to on this mobile ..but cant do that, i try to on this mobile so many ways.. i want to whhy thi mobile not on and how to resolve it?
